The hot water should be as hot as the inlet temp water.
170degrees. There is no internal heater to increase the water temp.
Please check that the hot water supply valve is turned on.
Check the hot water inlet hose is not kinked.
Also - remove the hot water hose and make sure the shipping plug from the hose hookup was removed.
If the hot water supply is on, and there is verified hot water coming from the hose (into a bucket) it will be time for some warranty work - as your mixing valve solenoid (hot side) has failed.
Thanks for using FixYa!!
