Use the control panel select 2 side from single sheets or double side original
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Double-sided copy output
In print dialogue box there will be a setting for long or short edge binding, associated with duplex printing. Find it and try it. Good Luck.
SOURCE: my bizhub 350 is starting to make " dirties copies"
Proper service and periodic maintenance is required for your Biz.its drum unit's life is 1 lac copies.
Select your printers properties
Duplex printing
You can print a document onto both side of a page. This comes in handy
when you want to bind multiple-page documents.
1 Click the Layout tab.
2 From the "Double Sides" drop-down list, select "Double-Sided".
Note
The binding orientation can be specified from the "Binding Position"
drop-down list.
