Replacing the wash cycle selector knob on an Ariston AV 105 washing machine can be done with the following steps:
Turn off the washing machine and unplug it from the power source.
Locate the wash cycle selector knob on the control panel of the washing machine.
Remove the old wash cycle selector knob by pulling it straight off the control panel.
Inspect the knob shaft to ensure that it is not damaged or worn. If the shaft is damaged, it may need to be replaced before installing the new knob.
Align the new wash cycle selector knob onto the knob shaft, ensuring that it is fully seated.
Push the new knob firmly onto the knob shaft until it clicks into place.
Test the new wash cycle selector knob by turning it to different wash cycle settings to ensure that it is functioning correctly.
Once you are satisfied that the new knob is working properly, plug the washing machine back into the power source and turn it on.
If you do not have a replacement knob, you can contact Ariston or a local appliance parts supplier to obtain the correct part. Make sure to have the model number and serial number of your washing machine on hand when ordering a replacement knob to ensure that you receive the correct part.
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position. 10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00 being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
push on power knobs for radios are a two operation switch. push in to turn on and then push in to turn off. The switch is like a rocker switch in operation. the knob will not stay in once the radio is on as it has to be in an out position so that you can push it in again to turn it off.
Does the knob click or have a detent when you turn if fully clockwise? You should feel a little resistance before it is fully to the off direction. There is a blue LED that indicates power is on... note that it might take a little time to fully go out when switch is turned off as the capacitors do hold a charge and LED's take very little to illuminate. If both units are acting the same, I suspect you may not be turning the knob quite hard enough to turn off the switch... you should not force it, but it will offer a bit of resistance.
With most garage door openers, you can look under the light bulb cover and you'll find two numbered knobs. These knobs set the motor torque/speed ratio. Basically, if the door is really smooth having the knob turned down will make the motor go faster. Turning the knob up will give the motor move "oomp" but it will move a little slower. One knob adjusts the power going up and the other knob adjusts the power going down. This basically depends on how good the springs are working on the door itself. So just adjust the knobs until the motor is running each direction "comfortably".
skimmerle check your connections where your cord attaches to the stove.may be burnt or loose.if ok check wall outlet also 4 loose connections.i think whats happening is you turn the knob and that allows one side of the power thru to the clock so comes on /then turn off power drops out.give what ive said a good visiual inspectionGod bless,tom
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time
to confirm functionality.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold
5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can
be opened.
7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble.
8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test).
9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the
washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To
prevent injury, DO NOT put your hands inside when the tub is rotating.
10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation:
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together
for a few seconds until wash cycle LEDs appear.
If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED’s on the
right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the
control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal
operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
• Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return th e w a s h e r t o n o r m a l o p e r a t i o n .
Many times the knobs get spun all the way around, and the adjustment screws on the backside of the knob, slide out of place. Try to "play" with knob, turn to a position where it will turn off. Turn off the breaker, and take the knob off, adjust the screws and you should be ok.
