Could this be a lamp issue or T-con board?
SOURCE: yellow line on left side of screen-
If this is only happening on one input like your cable input and the dvd player is working great on a different input, then the issue can possibly be signal related and not a problem with the tv, if this haapens on any input you are watching, check to see if it affects the menu if it does then your looking at a Logic board issue, if it doesn't affect the menu but happens on multiple inputs then you have to replace the signal board
SOURCE: The screen is dark on the left side and Colored vertical lines
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
