See D-Link's support site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1513/
for documentation and drivers for your router.
SOURCE: dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
SOURCE: Cannot connect to Dlink DAP-1522 at 192.168.0.50.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
