Seeing my last answe, I can try you almost certainly, the cable is no longer available. I wouls suggest at this point, wire a ribbon cable from the inside of each unit, pull the cable out through a ventalation slot, and do the same with the next unit and cable. Good luck.Seeing my last answe, I can try you almost certainly, the cable is no longer available. I wouls suggest at this point, wire a ribbon cable from the inside of each unit, pull the cable out through a ventalation slot, and do the same with the next unit and cable. Good luck.
You can't post conmments that contain an email address.
There are many ribbons on desktop computers Hard drive ribbon ide cables , floopy drive ribbon cables cd/dvd drive ribbon cables .keyboard ribbon cables , lcd screen ribbon cables......
Hi, I recommend that buy an SCART to RCA/S-video adapter and use that one connection.. here is an example of SCART TO COMPONENT & S-VIDEO adapter on the URL below.. you can have a cable that one end SCART and the other end whatever you have on the TV.. check on eBay..
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
If you have a blueray or HD DVD player I would connect using a gold plated HDMI cable from the TV to the DVD, make sure that you buy the correct HDMI version for your TV. If you don't have a HS DVD player recorder then use a HQ SCART as below.
Most SKY+ boxes still have a SCART connection I suggest that you buy a HQ gold plated ribbon connector to connect the SKY to one of your AV (audio visual) channels. The benefit of using SCART is that it will autoselect the AV channel when SKY is taken out of standby.
You will not need to connect using co-axial cables these are pretty much redundant now as you can get all your channels through your SKY dish.
Also if you live in a poor reception area and your TV has freeview built in SKY is your better option.
Solution for Pioneer DV-C36 Multi Disk DVD player - tray door will not stay open.
My player would open the disk tray when the open button was press but when the tray was fully open it would retract back into the unit leaving no time to change or load disks. I found a poor connection at the ribbon cable connector was causing this problem. A seven conductor ribbon cable connects the main unit with the travelling tray. A position switch (S21) senses when the tray is fully extended and retracted. On my player pin 1 of the ribbon cable connector on the travelling tray was not making an electrical connection which causes the control system to retract the tray. The fault lies in the connector - the tang was not pressing against the ribbon cable conductor. I was able to desolder the connector and pull the contact out just far enough to reform the tang with fine needle nose pliers. This is very tedious and required an eye loupe for magnification. Tools required: #1 and #2 phillips screwdrivers Soldering and desoldering irons (or other desoldering tools) Fine needle nose pliers.
Remove the tray ribbon cable 1. Remove the cabinet cover - 6 screws. Open the tray. To keep the tray from retracting pull the power cord when the tray is extended. 2. Remove the front bezel from the tray. Gently pry up the bezel by relesing the catches with a small screwdriver. Allow the tray to retract. 3. Remove the front panel - undo large ribbon and wire connections on right, remove screws left and right, release two catch tangs on bottom edge using a small screwdriver on the inside of the unit. 4. Remove the white plastic cover over the laser mechanism ( 2 screws) Remove the disk carrier by removing the center screw. 5. Extend the tray again. When the tray is out the small ribbon cable is visible below the tray. Undo the ribon cable where it attaches to the main unit unit. 6. To slide the tray off the main unit use a small screwdriver to depress the stop catches (2) in the tray. They are molded into the tray. Pull the tray out further then lift up. 7. Flip over the tray and find the small circuit board the ribbon cable goes to. Desolder the motor wires (red and black) and remove the 2 screws holding the circuit board and position switch.
Use a multimeter to confirm there is an open or poor connection in the ribbon cable connector.
Remove the ribon cable and inspect the connector with an eye loupe or other magnification device. On my player contact #1 was not positioned properly to press against the ribbon cable conductor. You can either replace the connector or repair it. Warning: repairing the connector may damage it. To repair the contact desolder the connector from the circuit board. Bend the circuit board prong straight and push it into the body of the connector which will extend the contact out and the contact can be reformed. Be very gentle. Bending the contact may cause it to break.
Reassembly is the reverse. Don't forget to solder the motor wires with the proper polarity. Red and Black are labeled on the circuit board.
