here's how:print double sided pages1. Set
your computer software for double sided printing if you have a printer
that is compatible. Double sided printers are generally professional
style machines, and most offices, schools and libraries will have them.
On a PC, go to the drop down "File" menu and select "Double Sided
Printing" under the "Preferences" or "Properties" window and print. If
you have a MAC, click "Copies and Pages" under the "File" menu, select
"Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting
your PC writing software. When you are ready to print, click on the
drop down "File" menu and select "Print." From the "Print" window
select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with
MAC writing software. Select "Print" from the drop down "File" menu and
click on the arrow to drop the "Copies & Pages" menu. Under the
"Copies & Pages" menu, select "Paper Handling" and then click on
"Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as
usual. It is a good idea to mark the top of your first page with a
pencil so that you know the direction and side of the page your printer
prints. Use the mark to determine how to turn your pages and place them
back in the printer. Select "Even Pages Only" or "Even Numbered Pages"
and print again.
$('.Article .Steps .Image').each(function(i,e){
e = $(e);
e.find('img').error(function(){
$(this).unbind();
e.remove();
