body {
background: #FFFFFF;
margin: 0px;
padding: 4px;
font-family: arial, verdana, sans-serif;
font-size: 10pt;
p {
margin:0px;
padding:0px;
.spwrap
background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom;
You are talking about length of time to get hot water from water heater.What diameter pipe are you talking about? What type of faucet do you have?
1/2" pipe has inside diameter of .54" and holds 1.2 gallons per 100 feet
10 meters is 32 feet and holds .4 gallons
Average faucet puts out 2 gallons per minute, so 30 seconds you should get 1 gallon of water.
Put a bucket under faucet and check amount of water flow.
Assuming you draw just hot water from the faucet, then 30 seconds is slow for receiving hot water.
If you have single-handle faucet and raise handle straight up in middle, then you are drawing half hot and half cold, so it would take 30 seconds for hot to arrive.
If hot water is slow, the problem might be crossover.
http://waterheatertimer.org/Crossover.htmlor low water pressure due to clog in water line
http://waterheatertimer.org/Low-hot-water-pressure.htmlOther problems could include clogged water filter, clogged water softener, defective pressure valve, and low water pressure.
Sources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.htmlhttp://waterheatertimer.org/Water-heater-recirculation-system.html
We are willing to help, but we're not physic. Give some useful info: What have you done so far? This heater has a computer control module with has a display showing error codes. Make sure you've told us the module model and software version installed, along with every adjustment you've tried. More info = better answers.
