Memory upgrade, download upgrade to run 1 G 400 avaiable?
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Just refer to your laptop manual. If your manual got lost go to the acer website and find your product and download the manual.http://www.acer.com.ph/ac/en/PH/content/home .
when upgrading your memory you have to consider the following:
the processor: if your processor has 4gb compatibility mem you can upgrade upto 6 to 8gb.
take note that you must not exceed to 8gb or else your processor might be damage.
get the processor speed: example core 2 i3 processor, 1.0GHZ-the frequency.
the Memory or RAM(random access memory): get ther specification: example is DDR1 or DDR3
PC133 or PC 400. Thats all.
Note: your current memory must have the same memory module(example PC400,PC 133) or else it wont work.if your going to upgrade your current 4gb PC400 you have to add 4gb memory in PC400 module also.
