Have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd playerto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
The antenna in/out should be in your tv. there should be a cable that connects the vcr to the tv.
Talk to a tv expert
Thanks,johndoe43568 for a response,it was one of those days when everything goes wrong,the wife is moaning that her VCR is broken,I did a quick check on the sylvania,it would not accept the tape,so I went to Walmart and picked up the Magnavox VCR {which did not have an internal tuner}.I hacked for awhile,then took it back,got a JVC DRMV150B from Samsclub....it has an internal tuner,Beautiful and all is right with the world,I also repaired the Sylvania VCR,it had a broken belt for the insert and eject drive.I am new to the fixya site,so I will be back quite often to observe different equipment fixes. Thanks and have a good day DAVETEK
