SOURCE: printing on Canon NP 6035
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Sorry, the Canon NP 6220 is an Analog copier. All NP series copiers are Analog. You need a Digital copier in order to connect to a PC.
SOURCE: NP 4050 -
The door may be closed, but there is a inter lock switch that is not being closed. If you have all four paper tray, try to turn the copier off and disconnect the bottom two cassette's from the back of the copier and turn it back "ON" and see if the copier works. If it dose you have a problem with the bottom two tray's. You have a very old copier, can you do with out them? If not the switches are toward the front & it may just be knocked out of place... Good Luck...
SOURCE: problem with my copier Canon np 4050 Error code: 540
my xerox mashine is create problem Eror
E203 ?
pls
SOURCE: my canon np 6030 copier
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
