Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This will make it a hard reset. If you wish to do a system reset, you should enter its service mode option. google.com/+GopakumarGopalan
i have tv samsung model samsung lcd tv model la32c400...when you open the power on. they have a raster but it is hung .up...and then we open again the power booton on pwer it is have only light display ...and also based side have small line ruster only 3cm....what cause this and problem the t-conn....has fixed already in lcd or disposable .....what is the solution on this parblem......some help.....plssss txt me 09991375154 thank u.....
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
due to marketing and studies these companies are under the assumption that everyone that purchases a new tv is also buying a surround sound system. to cut cost they and save weight they go with lighter speakers. and then there is the this thing with loud sounds being the cause of people going deaf so to prevent that the manufacturer of your tv sets the decibels to an acceptable level because they care.even a tv from the eighties sounds better than most tvs today
You should call Devant's hotline now to verify the problem. Be prepare to present the model number and serial number located at the back of the TV. Devant's hotline is 3029700.
