SOURCE: PowerShot A95 does not power on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
SOURCE: My A95 Powershot pictures all look pink
Its known problem of ccd imager in Canon A95 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Thanks.
SOURCE: Canon PowerShot A95 will no longer power up
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. Pay particular attention to the small contact switches on the battery and flash card doors. Also inspect the battery contact prongs to make sure they haven't been bent to the point that they're not springing the battery to make contact with the battery door.
Testimonial: ""Some simple things to try" had the answer! The flash card door switch was not being closed (door pin had chipped off). Thanks loads for the help!"
SOURCE: POWERSHOT A95. In brighter light photos are
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
SOURCE: canon powershot a95
This is either a "stuck shutter" or "CCD image sensor failure". If the latter, Canon will fix for free (more details later). First you need to check if it's a stuck shutter problem.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
If movement is seen, then it's likely a failed CCD, for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
