How do I check the front fork fluid on my 2001 yamaha 650 classic
Idoubt your fork fluid levels have anything to do with uneven tyre wear,depending on where you live dictates how your tyre wears,if you live in uk then you tend to turn right more than left therefore wearing the tyre more on the right and reverse this for anywhere they drive on the wrong side of the road.tyre pressures are important... to check the fork fluid level you need to drain the oil into a measuring jug,compare result to manufacturers recommendation.if you are not mechanically competent do not attemt this as you may get hurt as the fork internals are under load from a spring
