Question about Jensen VM9725BT
Screen is black, nothing work on vm9725bt - Jensen VM9725BT
  • messened
    messened Jan 31, 2014
    i installed a Jensen VM9725BT gps, audio system... initially work great until my iPhone couldn't connect to head unit (BT screen said "Reading") and my phone couldn't get the link to pair... that said i download the firmware from jensenmobile.com and follow the process to installed again. everything was installed but the BT. After many attempt i was going no where until i find that BT:HW05-SW01.34.00 was also in the clarion audio system so i tried that... wrong decision!!! now my head unit only shows a black screen and although i tried to re-install the MCU, MPU,OS, MPEG (screen is totally blank and nothing works). So, How can i re-install the proper firmware? and if can get the unit back... how can i deal with BT to get it working again? i just spent a lot of money and now i have a box not working at all... Please help!
Black screen on acer aspire 9300
Hello, have you tried reseating the memory, taking out memory and installing another? It could be a faulty memory module and if it isnt that sounds like the graphics processor on the motherboard is faulty. That requires advanced soldering skills. Hope this helps.
Chat Live Remote Support
Facebook
Feb 22, 2013 | Acer Aspire Computers & Internet
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
Black screen start up and nothing
If the laptop appears to be working other than the screen hook a monitor to the video output, if you get a picture on the monitor you can evaluate what is working, but if the symptom is the same the video graphics chip or the motherboard is the issue.
Jul 03, 2012 | NEC Versa VX Notebook
Screen black, although it is ON. Nothing happens
HI This is kamal
it very simple just change ur ram
definitely ur compaq pc laptop would run
and let me know it would be working or not
regards
kamal singh
Oct 08, 2009 | Compaq Computers & Internet
Black screen. Nothing happens. It was working fine this morning. Took it out to play it after work. Nothing. The screen is black.
Does the zune software or Windows recognize the device? if so, you may need to update it, or re-set it.
the zune software and website will have information on how to do this. Hopefully the problem can be solved with an update rather than a complete re-setting of the device.
Oct 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
Sony vaio laptop VGN-AX570G
Try connecting an external monitor - if you get a picture then the laptop screen may be faulty or turned off.
Mar 14, 2008 | Computers & Internet
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
Jensen VM9725BT Logo
78 people viewed this question
Top Jensen GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Jensen GPS Expert? Answer questions, earn points and help others
