GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Jun 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE microwave with the message sensor error
Anonymous
Level 3:
  • Master 10,515 Answers
  • Posted on Jun 04, 2009
Anonymous
Master
Level 3:
Answers
10515
Questions
Helped
2934551
Points
31530
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
5 Related Answers
Anonymous
  • 111 Answers
  • Posted on Dec 20, 2008
SOURCE: ge spacemaker II microwave. sensor error lite comes on
Sounds to me like you have a bad magnetron tube. Call GE Factory Service as there is either a 5 or 10 year parts warranty. Or schedule a service call online at www.geappliances.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 06, 2009
SOURCE: Ge microwave stopped working and gave a sensor
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
  • The humidity sensor (gas sensor) has failed.
Maybe the controller is "scrambled" and a hard reset will fix it.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Anonymous
  • 1871 Answers
  • Posted on Mar 29, 2010
SOURCE: GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Anonymous
  • 43501 Answers
  • Posted on Aug 07, 2010
SOURCE: GE Spacemaker JVM1443
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
espressonist
espressonist
  • 1711 Answers
  • Posted on Dec 26, 2010
SOURCE: ge psacemaker microwave oven no working it started
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
1helpful
Code F2 upper thermal sensor
please follow the steps use the VOM and test it. God bless you
F2: 3123f39f-6d87-4596-8303-294a18c6bec2.gifCheck oven thermistor for continuity. Replace if zero or infinite ohms.
3helpful
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
pad).
1helpful
Error Message F-5
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor.
What is the F4 error fault in GE micro oven
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor hope this helps please remember to rank how this opinion helped in your appliance situation have a great day if i can answer any futher questions please message me back have a great day
rickead1
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
Error message SE
Hello :
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect .
I hope this will help you .
please rate !
1helpful
Hello :
good luck .
please rate !
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
1helpful
GE Profile Sensor Microwave Oven model JE1660
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
yettu
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
