Question about Smart Pulse Livescribe pen
The display went dark, I tried to update the firmware as the customer representative suggested, but unfortunately, the issue still exists. I also lost the proof of purchase and my pen hasn't been registered. What can I do to fix the issue? Thanks!
Rimage 3400 auto loader
R U sure the firmware update was the correct update and that it installed successfully? Check in the firmware part of the burning program to obtain a list of the currently installed firmware.
Apr 07, 2014 | Rimage Professional 3400 NSS CD/DVD...
The back ground is all blue
Try updating the firmware of your printer. Just go to www.lexmarklabs.com/firmware and choose the model number of your printer.
After applying the firmware update, try to do a "Deep Clean Printhead". To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If you still have the same problem, please go to this link for more info: http://bit.ly/mDKqh7
Mar 13, 2011 | Lexmark Prospect Pro205 Wireless...
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
So i recently bought this psp 2001, the version is 5.00m33-3 and the color is metallic blue. I can run certain games like monster hunter freedom unite and naruto ultimate ninja heroes 3, however , when...
well you are running a custom firmware and its probably having update issues if the custom side of the psp is outweighing the potential to run umd discs efficiently then just update the m33 out of the unit or download a firmware emulator for it i had to on my virgin firmware unit but even these get put out and never updated to run newer firmwares so its a shot in the dark for you but try it so google psp hacks and homebrews and there islots of sites with goodies you can use that custom firmware for even used for loading your iso games rite off the memory card instead of discs ok look around and you will be surprised what a custom psp can do:)
Jan 07, 2011 | Sony PlayStation Portable (PSP) Slim...
I purchased this useless Sony Dream Machine ICFCL75I 5 months ago. First time the freezing problem happened within a month after the purchase. Then machine hangs and thus cause the alarm not to go off....
Have the same issue and this works for me, Unplug the unit and plug it back in at least once a week. I've been doing this for over a year and a half and it hasn't froze up on me. This was an expensive piece of ****, because of this I won't buy Sony again.
Aug 25, 2010 | Sony Dream Machine FMAM radio with...
I accidentally updated my psp to 6.20 now how can i downgrade it to 5.30 again is anybody can suggest what to do
well if its a 3000 ur out of luck, im sorry but you cant downgrade 3000, if you have a 2000 or below then you need a pandoras battry and only phat batterys can be pandorized and you need the necessary firmwares and custom firmwares,
try googling psp hacks.com go there they may help you as they update their site with new software that is coming out for the newer psps, not psp gos though
Jan 15, 2010 | Sony PlayStation Portable (PSP) Console
Does exist update of firmware for C
Unfortunately this update doesn't exist. T
May 12, 2009 | Sony DVP-NS430 DVD Player
I try to update my psp and this error drffffffd7 appears
Your psp is on custom firmware if you got this error code. Simply put it will not update with official updates given out be sony. If you wish to update it, you have to go to Dark-Alex's page and download the custom firmware version you want.
Mar 18, 2009 | Nintendo Game Boy Advance Console
HAVE CX11NF...I believe there are faxes in memory.....how do I get them to print...I went to fax mnode/memu/printing report/memory job info....result is printing job is flashing inb memory job window...and...
You have an early model unit, there is a known glitch in the firmware and you will need to contact epson to update the firmware. The glitch causes the unit to recieve faxes, but it will not transmit them to print. Unfortunately, when you get the firmware updated all of your faxes will be lost anyway. Epson is well aware of this problem and should update the firmware for nothing under warranty, even if the unit is out of warranty. Contact epson in your country and get them out to fix the issue. If they try to charge you, let them know that this is not the fault of the user and that they have known of this issue for a few years now. Trust me, they will come to the party if you scream loud enough.
Gremlin11
Dec 03, 2008 | Epson ACULASER CX11NF All-In-One Printer
Smart Pulse Livescribe pen Logo
228 people viewed this question
Top Smart Computers & Internet Experts
Marvin
Marvin
pawnpower
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
