I'm trying to forward ports and i need to be able to go in to the setting but there is nothing to click when i get inside the router. any ideas?
SOURCE: no matter what i do, ports will not forward
http://portforward.com/
or call your internet provider.
SOURCE: my xbox is connected to
I know what you're going through as it is common on Belkin routers. There are actually some good solutions to this found on youtube for simple instruction to help demostrate but I'm gleaned you already have done some of the advanced steps. Here is my question did you ever set your xbox 360 with a static ip address and then add it to the firewall/virtual server settings. You put the static ip address in and the xbox 360 ports.
SOURCE: I am trying to get
Was it working befor you used a static IP in the device? check the firewall rules, you could try seting a dynamic IP on the device than looke for it in the DHCP table of the router to open the correct ports to the correct IP (temporarely) to see if *** works, than do the same with a static IP (STEP BY STEP) there is no reason for it not working with static IP versus dynamic IP, you could also try a DMZ on the IP's device (temporary) to make sure it's not the firewall
SOURCE: Hello my name is Ben I
Hey Ben, when you access your settings page do you see the option for applications and gaming? That's where you would change the nat.. Just remember that you must set the start and end ports correctly and you must put in the correct IP address before enabling it.. Let me know if this solved the problem and good luck..
Once you open the set up interface of
the router, you will be able to find the settings on the router where
you can open the ports for the particular program.
If you
are opening the ports for a special device in your network, then you
must know the IP address of that device.
For
example, wireless camera, DVR, X-box, Play station ...
You
can choose the option PORT FORWARDING for a
special device application.
If you
just want to open the ports for all the network, then you can choose PORT
TRIGGERING
For Linksys Router.
You have opened the set up interface of
the router. You will see Application and Gaming TAB at the top.
If you
click on that tab you will find different Sub tabs.
Click on
Port Triggering => Here you can open the port numbers for the
network.
Click On Port forwarding if you want to
open the ports for a special device in the network.
Click
Save settings once you open the ports on the router.
For D-link router
the router.
You will see Network settings in the
left hand side panel of the page.
Click on
Network settings and go to the Advanced TAB at the top.
Now you
will find the option. Pot Forwarding in the left hand panel.
Here you
can open the ports on the router.
BELKIN wireless router
the router.
Click on Virtual Servers under Firewall
in the menu on the left
Click Enabled. Type a
general description of the application i.e.. Remote Desktop. Type the
port(s) specified by the program manufacture for both of the Inbound
port fields. Select TCP, UDP, or BOTH for the Type.Private IP address:
Enter the IP address of the computer you want grant access too. Type the
port(s) specified by the program manufacture for both of the Private
port fields.Click the Apply Changes button.
NETGEAR Router.
the router.
Click on Port
Triggering under Advanced menu.
Change
the value of Port Triggering Timeout as 20 Click on
Add Service. Specify a
Unique/User Defined name under Service
Name. Ex: Mails, VPN. Specify the Service
User as Any (if all
the computers in the network are port triggered or if a single computer
on a network is port triggered specify the IP address of the computer).
Select the Service Type of the
port to be triggered
Ex: TCP . Specify the Trigger
Port (The
port to be triggered). Select the Connection
Type of Inbound Connection. Specify the
Starting and Ending Port for Inbound Connection. Click Apply to
accept changes. Your router is now set up for port triggering..
If you
For
You
If you
TRIGGERING
For Linksys Router.
If you
Click on
network.
Click
For D-link router
the router.
Click on
Now you
Here you
the router.
NETGEAR Router.
the router.
Click on Port
Change
User as Any (if all
Port (The
You need to setup port forwarding read below.
If you
For
You
If you
TRIGGERING
For Linksys Router.
If you
Click on
network.
Click
For D-link router
the router.
Click on
Now you
Here you
the router.
NETGEAR Router.
the router.
Click on Port
Change
User as Any (if all
Port (The
http://www.youtube.com/watch?v=fYwd0YkXdY0&feature=related
If you
For
You
If you
TRIGGERING
For Linksys Router.
If you
Click on
network.
Click
For D-link router
the router.
Click on
Now you
Here you
the router.
NETGEAR Router.
the router.
Click on Port
Change
User as Any (if all
Port (The
If you
For
You
If you
TRIGGERING
For Linksys Router.
If you
Click on
network.
Click
For D-link router
the router.
Click on
Now you
Here you
the router.
NETGEAR Router.
the router.
Click on Port
Change
User as Any (if all
Port (The
