SOURCE: acer aspire 3000 display problem
i think its ur video card that has a problem.. try bringing ur laptop to the company of yuor laptop 2 fixed your problem.. hope it can help
SOURCE: i have acer aspire one 532h with original window xp.
Turn off the system , Turn it back on , as soon as it turns on hold down the Alt Gr and tapp the F10 Key without stopping , you can see windows loading file ,it will take you to recovery console , select restore system to factory defaults
SOURCE: my acer aspire one 532h-2db
Thank you for contacting Fixya. This is Anil.
I understand that the Netbook starts but there is not display on the screen.
It may happen due BIOS failure on the computer. Try updateing the BIOS. Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
Go http://gd.panam.acer.com/home/ and download the latest BIOS for the netbook.
Extract the files from the downloaded zipped BIOS file.
In the Dos folder, Copy Flash.Bat; Flashit.exe; Nav50.fd to the USB flash drive
Ensure that the AC adapter is plugged in.
Insert the USB flash drive into a USB port.
Press and Hold down the Fn and the Esc keys together and press the power button.
When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
After the keys have been released the power light will start to blink.
During the BIOS update process the display will be blank.
Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
SOURCE: my acer aspire one 532h blank screen when turn on
Its may b ur vga fault so repace ur vga and chek it
