I wish to block unwanted calls on my Samsung Phone, is this possible
To block unwanted calls, it's very easy with some apps, here I can recommand you LEO Privacy, cause I've used it for 1 year.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Block All Calls
Step 1
Press the "Menu" key while the home screen is visible. Choose "Settings."
Step 2
Select "Call" and then choose "Call Rejection."
Step 3
Choose "Auto Reject Mode." Press "All Numbers." Any incoming call will now be rejected.
Block Specific Callers
Step 1
Select "Contacts" from the main screen.
Step 2
Choose either "Logs" or "Contacts." Browse the list of people and select the contact to block.
Step 3
Select "Add to Blacklist." The selected caller will now be rejected.
Tips
i am getting calls from different unknown numbers , thats the reason need to block all except the ones in contact, whatever you have suggested will either block all the phone calls or will block specific, in my case i dont have any specific number to be blocked but want to block all except the one in contact.
Yes, in phone number recall area. number history. find number you want to block hit settings then add to reject list.
SOURCE: need to block numbers from calling me
Unfortunately, there is no way to block numbers from calling you. You can change your number or simply don't answer. Sorry! I wish they would make a way!
If there is a way to make it where only people in your contacts can call you it would be under main> settings> security> restriction, but I doubt it.
SOURCE: I want to block unwanted
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
SOURCE: how to block unwanted numbers calling &
Hello
Welcome to Fixya!!
Have a look at the link below. It is a tip i wrote on how to initialize the reject list.
Click HERE to navigate.
Please feel free to let me know if you have any further questions.
Kind regards
lock123
I'm now using LEO Privacy to block unwanted calls on my samsung phone, this is very useful and very safe, you can have a try.
