We all read lots of tips when it comes to saving water....but this tip is probably the best kept secret in the water saving arena!! Whenever you are preparing the water for a shower begin by turning the hot water on full and leaving the cold water completely off UNTIL the hot water begins to flow. THEN add the cold into the mix. Other wise, you send hundreds of gallons of cold water down the drain if you begin by letting a mixture of hot and cold run until it finally gets hot. WHY is this the case. Because, the hot water sitting in the hot water pipe cools off over time. The only way to actually get the hot water to the spout is to displace all of the cooled off water out of the hot water pipe until the hot water starts to flow again!
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Turn off the
water valves which supply the water to washer hoses.Switch the hot and cold water supply hoses
and tighten. Turn the water valves back on and try to run a wash cycle using
cold. If hot water only is entering the wash tub the water supply is ok. If
this is the case you can unplug the washer and turn off the water valves. Remove
the washer back cover and follow the water connection for the hot water. The
water solenoid valve will have two electrical wires connected
to it. Interchange the hot water solenoid wires with the cold water solenoid connection.
Connect the water supply hoses hot to hot and cold to cold then plug the unit then
test the washer on the cold wash. If the problem persists it could be a water
hose restriction or the timer circuit could be defective. If you have hot water
at the normal pressure purchase a new hot water solenoid valve.With the electrical cord unplugged be sure to
restore the correct wire connections on the hot and cold water solenoid. To
replace the hot water solenoid remove the hose clamp and hose to replace the
old valve. Connect the unit to the water and electrical outlet. Turn on the
water and test the unit for leaks being careful not to touch any electrical and
moving parts. If all checks ok and the correct temperature work, unplug the unit
and reassemble.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
I have never heard of this before, and have always piped dishwashers off the hot water line. Not to say it could not be done the other way, I would refer to the instructions that came with the dishwasher, and if they say to connect to the hot water line, to have the technician come back and fix it. If it says to connect to cold water line, then manufacturers know best.....Hope this helps
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
