Nixon Lodown Tide watch Logo
A
Anonymous Posted on Jan 30, 2014
Change battery nixon watch - Nixon Lodown Tide watch
4 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 10, 2009
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 28, 2009
SOURCE: battery change for Nixon Kink watch
You have to open your watch caseback. Undo the battery holding contact, get the battery out and memorise the writings on the battery. Buy exactly the same one and replace it in the backwards way you took it out.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Apr 25, 2010
SOURCE: get the user manual for nixon banks watch
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
Anonymous
  • 5 Answers
  • Posted on Apr 14, 2012
SOURCE: user manual for nixon delta pu watch
Here you go,
http://www.nixon.com/manuals/nixon_delta.pdf
1helpful
Had battery changed on my Nixon and the second hand doesn’t move ?
The person who changed the battery has probably disturbed the hands and disconnected it. Take it back and make them fix it or have it fixed. Same thing happened to my Swiss-made Tissot. Spent $7 to have the battery changed, cost me $1,000 watch. They don't have the parts for my Tissot any more.
2answers
What size battery does a Nixon Take Charge"Corprale" quartz watch take?
Pull the battery out of the watch, the number is stamped on the battery negative side, go on eBay and find the battery.
1helpful
2answers
It says rom fail on my lodown 2 and i was wondering if anyone knew how to reset the watch?
Here some tips to deal with a Nixon Lodown:
1) Sleeping mood (display is off, all buttons lead to the same reaction: display shows time for some secs and then turns off again. This mode is for battery energy saving, switch it on and off by holding (c.a. 2 secs) the light button.
2) ROM FAIL: it happens that the lodown shows ROM FAIL and constantly restarts. It happened on my watch while I tried to change time zones. Here is what to do about it: Bring it to a professional watch repair store and get the battery replaced. The watch restarts automatically and works perfectly fine again. DON'T send it to Nixon, they will charge you for shipping, battery replacement, the new battery etc. Although it should be covered by the guarantee. Just get a new battery, it cost me 16 USD and the watch is good again, waterproof and works perfectly. Nixon authorized repair centers will charge you extra for pressure testing. I had this on my second Lodown, after I had it two weeks only...
3) Watch freezes: All digits are on at the same time, none of the buttons brings a reaction. I had this problem on my first lodown. Just get a new battery, that solves the problem. But again DON'T use authorized Nixon repair centers, it costed me almost 45 USD, just to get a new battery. Although the watch was only 1 year old and guarantee should have covered this case.
In general the Nixon Lodown is a good watch, looks good, has all features you need, as long as it works. The problem with the watch is, the above problems occur pretty often. I have my second Lodown now and I am very disappointed with the Nixon customer service. Although clearly guarantee cases, they will charge you for every single problem you have with the watch. My advice, bring the watch to a regular watchmaker.
After all, I don't understand why the Nixon Lodown manual does not mention all the above issues. The manual is completely useless, very poor from Nixon. You have to dig online to solve any issues on the watch. In summary: The Nixon Lodown watch is good, Nixon customer service and guarantee is a joke. ROM FAIL and freeze is solved with replacing the battery.
4helpful
2answers
Rotolog watch isnt working is there a way to wind it up?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIXON watch manuals.Rate me, please.
2helpful
Battery change for Nixon Kink watch
35helpful
How to change the battery on a Nixon Scout Watch?
Top Nixon Watches Experts
ZJ Limited
ZJ Limited
john h
Are you a Nixon Watch Expert? Answer questions, earn points and help others
