Singer Golden Touch & Sew Deluxe zig zag model 630 the upper stitch pattern will not slide to k . The upper row must move to k in order to wind a bobbin . The lower stitch pattern must move to the A ( which it will Do ) Please help me fix my sewing machine . Thank you for you help in advance
SOURCE: Singer Golden Touch & Sew
Try a new needle first failing that you may need to retime the machine, you can email me for an attachment of instructions [email protected]
SOURCE: Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
