SOURCE: CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
SOURCE: Casio Ex-Z75 Battery not charging ?
This problem is known. There is a way to fix it.
The fact that it blinks on and off means that the battery is completely out of energy. Thus, the charger doesn't "recognize" the battery.
To fix the problem, you need to give some energy to the battery. What I usually do is that I use a 9V battery (or any other source of power) and I link + and - of both the Casio battery and the 9V battery. You can use a paperclip as a link (you will use 2 paperclips, 1 between minuses and 1 between pluses).
Do that for 2 minutes and then charge your battery as usual. It should work !
Sorry if my English isn't accurate. I'm French.
SOURCE: the light on the battery
from another thread, posted by theslug. This worked great for my camera.
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
SOURCE: battery won't charge on casio ex-z77 exilim
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
SOURCE: The battery (NP-20) for my
The chances are pretty good that the battery is bad. Buy a new battery - they are inexpensive.
