SOURCE: I have sixteen button NEC Electra ELite Multiline Telephones in my office-
Here's how you adjust the time:
1. Press <TRANSFER>
2. Press <CONF>
3. Press *
4. Press <TRANSFER>
5. Press <CONF>
6. Press #
7. "CAT MODE" displayed on LCD
8. Press <REDIAL or LNR/SPD>
9. "COMMAND" displayed on LCD
10. Press 02
11. Press <RECALL>
12. Press 2
13. Press <RECALL>
14. "02>2>Current Time" displayed on LCD
15. Input correct time using military time (HH MM SS)
16. Press <CONF>
SOURCE: VOICE MAIL NOT WORKING
Is it the type with a hard-drive mounted on the card?
If so, pull the card out of the system, let it sit for at least 15 minutes, then plug it back in. You might even try putting it in a refrigerator (just don't get it wet).
If it still doesn't come back online, it's time for a service call.
I hope you have a maintenance contract, though.
SOURCE: NEC Electra Elite
you need to access program mode. Did you contact your nec vendor? ldtsnj.com
SOURCE: Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
SOURCE: NEC Electra Elite 192 Phone System: Voicemail Directory
in your subscribers mailbox select yes you want to be included in you companies directory .
