SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Testimonial: "Thanks very much for the help. "
SOURCE: My VPL CS6 will not turn on. I tried different
It could be that you have put the projector into emergency mode. If this is the case you can only switch it on by moving the small switch by the leg tilt underneath, and then maually open the lamp cover by turning the adjuster with a coin, see page 48 of the manual for instructions. Hopw this helps
SOURCE: My Sony Data Projector VPL CS6 is stuck in
I tried the emergency mode and recovered the powered mode. just make sure you can turn the adjuster ( that big grey plastic screw) freely and leave it that way (don't tighten it or put the **** back in). try turning it on. works for me..
SOURCE: Sony Vpl -cs6 Lamp hour
Connect the power cord and turn on the projector.
When it's in standby mode, press the following keys on the remote in this order for less than 5 seconds each.
RESET
left arrow
right arrow
enter
