turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
I was experiencing the same exact issue recently. I had to do a hard reset on my tablet. I was scared at first because I was told by some that I would lose all my apps, videos, music, photos, etc. Then others told me I would not lose anything. I did a hard reset and everything was restored.....nothing lost.
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info for u. http://youtu.be/mK-AGDPtoNU Good luck Chad man
