Abit NF7-S Motherboard Logo
Posted on Jan 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abit NF7-s New 2GB PC3200 (2x 1GB) (running dual-channel) SATA HD and DVD-RW, new PSU, when booting, it stops at "Counting Memory". I can reboot (sometimes several times) and it will act normal again...Any Ideas?
Level 3:
  • Abit Master 19,187 Answers
  • Posted on Jan 30, 2014
Abit Master
Level 3:
Answers
19187
Questions
0
Helped
4339662
Points
82259
Take out the ram and reseat it. Try again, if you still have the problem, take out half the ram and test it and then switch it around till you find out what ram chips are possibly bad.
2 Related Answers
Anonymous
  • Posted on Mar 29, 2009
SOURCE: My Pc wont boot no signal in my monitor Help!
hi there..in mobo with platform p35 works the same like that on-off and on again,its normal so dont worry about that
the real problem is screen blank,i've got replaced new mobo with the same type,but the problem still the same.so its not the mobo problem i think.
Anonymous
  • 41 Answers
  • Posted on Jun 23, 2009
SOURCE: i need download drives of motherboard abit nf7-s2
Here is a link to a driver download:
http://members.driverguide.com/driver/detail.php?action=download&driverid=1270049
Hi. i have abit motherboard nf7 s2. i bought 2
Did you make sure to install the memory starting from DIMM3? You should install into DIMM3 then DIMM2 according to the NF7 manual.
1helpful
Abit NF7-s v2- hynix ram support problem
your system does not support the dual ddr ram unless you have a add-on VGA card
I have included the link to the user manual ... see chapter 1 section 1-1 Features and Specifications
Abit NF7-S v2
Supports DDR 400 only when using an add-on VGA card (NF7-M)
New Build PC not booting
do you get any onscreen information like a bios screen?
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
My Abit NF7-S v2.0 only works with one memory module at a time
I have read that there are dual memory controllers (duel channel) and that when you use 2GB like that you are using 1 memory controller for each stick. Maybe one of your memory controllers is bad... maybe popped a cap? Sounds like time for a new MB. See this thread...
http://www.motherboardpoint.com/t61060-nf7s2-can-it-use-highdensity-memory-chips.html
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
4 GiG memory
Your motherboard doesnot offer dual channel memory architechture and 2x2GB memory is taken in sigle channel mode. Apart from that 32bit Operating Systems don't recognise memory over 3 Gb. So you have the following options...
1. Attach only one 2GB
2. Attach 2GB + 1GB
3. Move up to a 64bit OS with your current 2x2GB memory modules.
Please collect memory module of the same frequency if you consider option 2.
My system is
I guess I'm missing something here?
Top Abit Computers & Internet Experts
ExpressFiX
ExpressFiX
JTR44
Level 1 Expert
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
