When paper is inserted it says document ready. When start button is hit you get a beep. No rollers appear to move or activate.
What model are you referring to? In general. When you load a document you get a beep and the screen will change waiting for you to enter the fax number. If this does not happen then the document detect sensor is not being activated so the machine does not know there is a doc on it. Open the document cover and look for a long black arm hanging down or standing up. Make sure it moves. There will be two other sensors also with black arms . make sure they are also free to move. If they are sticking then investigate as to why. use NO lubricants. just clean.
SOURCE: Fax Not working
Copying Documents
If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows:
* STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
You can select [STANDARD], [FINE] or [PHOTO].
To make a correction to the number of copies, press <Clear> and re-enter the number.
To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
SOURCE: auto feed of outgoing fax document.
Replacing the roller can be prety extensive work. Try to check and make that the pick-up roller on the bottom is flat across sometimes it can get turns backwards and it has a round side that will not grasp the paper. If this is ture just take your finger and push the roller forwards. You can alo take a clean wipe and wipe off all of the rollers the rollers are made to be a little tacky when they start to get a little older dust can build up on them causing them not to grab the paper
SOURCE: Canon L170 will not feed paper in for faxes or copies.
as the rollers move with the help of the side gears .which r made up of plastic and that gears r worn out or got cracked as due to this it pulls the paper but the gears are cracked so it does not pulls the paper further and it hangs in between.as to resove this the gears needs to be cleaned and checked if the problem not solved the gears neeeds to be replaced. thanks.
SOURCE: Display ... ''clear paper jam''
First clear the possible paper jam using a air blower on the rollers and sensors most possible cause is the paper dust which block the sensors. then do a power cycle by unplugging the cable and leave it turned off for 5 mins and then reconnect, it should take care of the issue.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
The unit detects paper, "document ready" then nothing...
