The pc shuts down on its own when being used. also the optical mouse is always running slow and keeps stopping, i have changed the batteries and they are ok, also the DVD player will not work,any suggestions , thanks
Run an Error check on your computer. Process takes anywhere from 1 to several hours, depending on hard drive size, files on computer and number of errors needing to be fixed.
Manual steps to run Chkdsk at the command prompt
loadTOCNode(3, 'moreinformation');
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
