Where can i get thethe schematic
'You can download Service Manual of BEHRINGER PMP6000. Check bulge capacitors in the power supply which causes the problem:
https://www.electronica-pt.com/esquema/audio/behringer-audio/behringer-pmp6000-34302/
You can get the entire service manual for this unit here:
BEHRINGER PMP6000 SCH Service Manual free download schematics eeprom...
SOURCE: i have a beringer eoropower pmp 5000. i run my
With the AB switch at the center position Mon1/Main you control the volumes INDIVIDUALLY with the MON pot for each input that is a couple positions above each of the input sliders.
SOURCE: I have a beringer pmp 5000. Out of the box, I
Yes, the fan is temperature controlled. You have to drive it a bit before it runs, and then it is kind of throttled versus temperature.
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
SOURCE: europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
SOURCE: power supply prpblem .dead set.the
If you have manual, schematic is in the back pages. If not go to Behringers' site and download PDF (I believe it's under support)
