Panasonic PT-47WX49 47" Rear Projection Television Logo
R
R Folk Posted on Jan 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic PT-53wx54j" Rear Projection Television blinking light 3 times, wont turn back on. Originally turned off by itself
Had the tv on running fine then it turned itself off. Now all I get is 3 blinking lights on the power light. Took off the back. Lifted the board. Looks like some brown marks (burn marks?) around the solder pins of the convergence ICs attached to the heat sinks. Have one of the blue resistors (R7014) gone grey in colour. I assume this means it is burned out. From everything I have read, it would indicate the convergence ICs (stk-392-110) have to be replaced due to overheating as well as the burned out resistor. Just want a double confirmation before i go and buy everything I need. Thanks
tostrokesmok
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 130 Answers
  • Posted on Jan 29, 2014
tostrokesmok
Expert
Level 2:
New Friend:
Greenhorn:
Answers
130
Questions
0
Helped
43090
Points
248
Sounds like a bad power supply my mother has one done the same thing we found out he power supply went bad $125 to fix so we junked it and she bought another TV
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Mar 24, 2008
SOURCE: Convergence Resistors
Can you check that location number again The parts list doesnt list a capacitor with that location number. Is the item a resistor or a capacitor ? Let me know the other site I work at has full service manuals with part numbers and specs in them. I will be able to tell you the specs on your part
Anonymous
  • 185 Answers
  • Posted on Nov 26, 2008
SOURCE: resistor identification
Hi fccjben;
The color code is as follows: blk = 0; brn =1; red = 2; orange = 3; yellow = 4; Green = 5: blue = 6; violet=7; Grey = 8; white = 9
Unfortunately, if it is wirewound, they usually printed the resistor value on the body of the resistor. For sure it shouldn't be glowing. Sorry I can't be more help, but without a schematid, can't do much else
Good luck Loringh
Anonymous
  • 7 Answers
  • Posted on Dec 02, 2008
SOURCE: I need to identify the
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Anonymous
  • 14553 Answers
  • Posted on May 19, 2010
SOURCE: My rear projection tv just failed me by turning
Yes, the three blinks is short protection. If one or more of the 2.2 ohm blue resistors is white in the middle one of the STK-392-110 chips got it.
I may be the one whose post you saw. I have start to finish step by step instructions for this repair in this set.
I can also tell you the best place to get them and the instructions tell you everything you will need and how to do the repair in the best way.
They are based on the fact that I have fixed hundreds of these sets with the same problem you have.
SD TECH
Anonymous
  • Posted on Sep 06, 2010
SOURCE: panasonic pt-47wx42f
I replaced the convergence chips, the tv comes on now, but turns itself off in just a few seconds. I need to know why.
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
1helpful
Panasonic cinema vision pt-53wx54j does not turn on. red power led blinks 3 times.
Hi
Thanks for using FixYa. 3 blinks means convergence output failure and to resolve this you’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
11helpful
2answers
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
5helpful
My panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
2answers
Pow lite flashes three times it tries to turn on then shuts down
LED 3 times blinks shows problem with convergence out section in TV and may requires convergence out ICs replacement.
If you are familiar with TV repair and can solder parts on PCB then let me know to provide you more technical info.
Thanks.
4helpful
2answers
Panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
