Hello my problem with the tv is it shut off by itself i can turn it on again but it shut off again it does this about every 10 hour just like clock work and sometimes it turn itself on by itself but the last time it shut itself off it would not come on either by remote or the switch on the tv
SOURCE: TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: tv keeps switching itself off
When that happens - try unplugging the tv for a few minuets & plug it back in.. Sometimes it will reset its self.. Or it could be a bad sercut or maybe a falty power suply.. Electronics is usually process of illimination - unfortunately..
SOURCE: Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Press the LOCK button to lock or unlock the TV.
When the TV is locked, the screen will turn to blue background, and nothing can be viewed unless you press
LOCK again to unlock it.
OK
[Sometimes you may need to press the LOCK button more than 5 seconds contnously to unlock the TV]
OK.
