HEWLETT-PACKARD CP1025nw Laser Printer Logo
A
Anonymous Posted on Jan 29, 2014
Hp cp1020 scanner error - HEWLETT-PACKARD CP1025nw Laser Printer
t d
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Oct 23, 2017
t d
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
5280
Points
50
I just cleaned the mirror inside the laser case after error 55.0000 which was having high speed rotation mirror .
Works fine now!!!
Used q-tip, was just a little "foggy".
  • t d
    t d Oct 26, 2017
    Sry, error 52; not, 55...
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
DOES HP CP1020 PRINT MIRROR IMAGE?
Print Image Mirror, do not depend on printer. Easy to make mirror image/text with office word :
4answers
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
1helpful
3answers
What is scanner error 2 on hp laserjet 3055
Flatbed scanner is bad replace whole top half p/n q6502-60116 approx. $150 - $200
5answers
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
1helpful
2answers
I have error 50.22.00 in my Hp M602 printer
Error: 52.XX.00 Error To continue turn off then on
Error Description: Laser/scanner error ? XX = 00 laser/scanner motor startup error ? XX = 20 Laser/scanner rotation error
check your printer scanner assy. need technician support.
4answers
117helpful
6answers
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
