I try to connect TV to my PC with HDMI-DVI cable, but TV shows no picture. It goes straight to power saving mode. Computer shows that devise is not recognized, but it shows that I can force connection to tv, but then it is showed as VGA device. OS is Win7 64bit and graphic card is ATI Radeon HD5450. My friend (which whom I bought TV) used TV with computer too, but she used HDMI cable and HDMI-DVI adapter and it worked.
I have had the same problem. If you have a VGA cable shown at the bottom. You can hook that into your laptop into the TV. The slots look like a blue incovering. You can also look at the image below that one for more additional help....
Testimonial: "TV has only DVI connection and I told that problem changed a bit. Sorry, nut your answer didn't help me at all."
SOURCE: I HAVE AN LG 42 PJ 350 R TV ... I HAVE MY PC
i think from your mobile virus had entered in tv reset the tv
SOURCE: Connecting LG 50PC3d to Computer
It sounds like you have the resolution of the PC set to an incompatable format for your TV.
SOURCE: Hi, I have bought LG LCD
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
SOURCE: Can't get sound to work with RBG cable from PC to TV
Sound will not work with mere RGB connection. The audio out of the PC should be conected to Audio in socket to TV.
The problem has changed a bit. I adjusted the resolution and now tv shows picture when starting up the computer. But TV goes back to power saving mode when computer logs in to my user. Computer has only one user (me) so it logs in automatically. Also, TV shows picture only when picture is copied to both displays (TV and monitor). So basically, no picture after logging in.
Have you changed your projector settings? Maybe this might be the problem....
