I tried to replace the batteries in my home phone and now my phone will not work. The base will ring but the handset will not. The screen will only flash up with the messages, battery, and signal symbols. It will not allow you to dial a number either
Hi, It sounds like the batteries of the handset could be the problem.
Try replacing the batteries with other new batteries. I recently purchased a good brand of battery (not rechargeable), but they were down in their voltage straight out of the package.
Make sure the batteries are AAA NiMH batteries, and that they are charged for at least 16 hours.
Also check that you have inserted them the correct way +ve/-ve.
When you have inserted them, place the phone on the base and the handset should show you it is charging.
SOURCE: One the additional handset and the base handset,
Pull battery out of handset for 5 minutes and replace. Then, sit each handset into base cradle until the unit(s) sync.
SOURCE: i need to download a copy of the user manual Telstra 7100A
I contacted Telstra and they offered a free copy if I go into any Telstra shop.
Cheers.
