When what is open? Always keep the battery / memory card door closed. If it is not closed correct, the camera won't work as expected. To protect the file system, when someone should pul out the memory card, while the camera is accessing the memory, it will or shut down completely, or at least protect the memory card against writing to it.
Before opening the battery / memory card cover, always make sure the camera is completely shut off. That means no light is allowed to burn or flicker. The memory card can also be write protected (SD cards) when the lock switch is down like in the picture on the 32GB card.
Before you can make any picture the switch on the card should be up like on the 64GB card on the picture.
