Dewalt DC925 Cordless Drill Logo
A
Anonymous Posted on Jan 29, 2014
Gearbox grease what should I use
tip
Mobility scooter gearbox
Is your scooter 6 months or more old ? please consider having the gearbox re-greased ? why ? well sadly most companies use something called grease however it 's awful... from going stiff to having no lubrication properties at all,,, get your gear re -greased , it will prolong the life of the scooter ...and keep the noise away.....
on Jul 11, 2015 • Miscellaneous
tip
GEARBOX DRIPPIN OIL KENWOOD CHEF
IF YOUR GEARBOX IS DRIPPING OIL TRY CHANGING THE GREASE INSIDE WITH SUPERLUPE FOODSAFE GREASE.AS YOUR OLD GRESE HAS PROBABLY BROKE DOWN AND LIQUIFIES. ALSO CHANGE OR WASH AND DRY THE FELT COVER UNDER GEARBOX.
**** AT KENWOODCHEFUSEDMIXERSANDSPARES.
07507400101
on Jan 05, 2010 • Food Mixers
1helpful
How do you change grease in gearbox ?
You open the gearbox up and scrape it out with your hand and maybe a screwdriver, then replace with the correct grease. For example Kitchen Aid use food grade grease.
Jul 15, 2015 • Food Mixers
How to change grease in gearbox
HOW DO I REMOVE THE AGITATOR TO FIX THE PROBLEM OF GREASE /TRANSMISSION FLUID GETTING ON THE CLOTHING DURING THE WASH. IS THAT THE SOURCE OF THE PROBLEM?
The top blunt end of the agitator is threaded and when removed allows to agitator to come off. Lots of lint and old soap accumulate there and can pretty much "glue" the agitator in place. Once gone, you will see the drive shaft from the gearbox sticking up. I think you need to pull the gearbox to get to the seal. The gearbox is filled with nasty surpy "blackjack" grease and can be reused. You might get the repair kit from the manufacturer. That will include all the seals and "O" rings needed to keep the tub from leaking and the grease inside the gearbox.
Oil leaking from bottom of gearbox
if a manual gearbox ,then its fairly easy to repair without stripping box and thats to pump a grease gun full of LM grease into gearbox as the grease will settle in the bottom of the box stopping the oil leak but a auto box will require looking at
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 • Drills
1helpful
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
