Not printing. The printer icon n control panel reads offline and an not be reset to online. the power light keeps blinking and would not come off even though i press it
my printer is not printing at allmy printer is not printing at all
AnonymousApr 13, 2008
my HP deskjet 3915 is blinking all the time even if I restart the computer and disconect it and the icon shows offline and number of documents i have tried to print. my HP deskjet 3915 is blinking all the time even if I restart the computer and disconect it and the icon shows offline and number of documents i have tried to print.
AnonymousOct 06, 2008
I can't print, and the power button keeps blinking even when I try to turn it off.I can't print, and the power button keeps blinking even when I try to turn it off.
You can't post conmments that contain an email address.
Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
Check the printer properties in the control panel. Look in the status column. If the status is paused or offline, select resume or online or reset from the Printer menu option. Sometimes you have to turn the printer off and back on for it to start again. If it is an inkjet printer, don't unplug it. Some printers get messed up if they are not powered off using the power button.
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online. PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.- Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.- Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.Mac Instructions - Open System Preferences by clicking on the icon in the Dock.- Go to the Print & Fax control panel under the Hardware category.- Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.- Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Make sure that cable to printer is attached and if printer still shows offline then in control panel for the printers make sure that you right click and choose Use Printer Online
What the flashing light means The Power light can flash for several reasons: ? The printer cover is open. ? The printer is out of paper. ? A problem exists with the printer, such as a paper jam or a problem with a print cartridge. For information
When you double click the Printer and Faxes icon in the Control Panel
you will see the printer that your computer is currently using. See....
if the printer image is clear it is online and ready to use, if its
blurred then its in offline mode and cannot be use.
To correct
offline printer.. some possible reasons is on the usb cable.. check if
there is no open wire along the cable...Inserting the USB connector on
the other usb slot of the cpu sometimes work just wait first until it
is read.
If the printer is still blurred and offline after
checking the usb connection, the 2nd thing to do is check the
properties of the printer if it is set to offline mode. how? Double
click your printer icon. It will display the print jobs window. Click
on the Printer tab and uncheck on the "Use printer Offline". Cancel all
pending print jobs, close the printer window and try again to print.
hi
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
·Step 1 Open the Start menu and click on the
printers currently set up on your computer. ·Step 2 Double-click on the icon of the
print jobs will open. ·Step 3 Go to Printer in the menu bar of
change the printer from offline to online. Mac
Instructions·Step 1 Open System Preferences by
clicking on the icon in the Dock. ·Step 2 Go to the Print & Fax
control panel under the Hardware category. ·Step 3 Select the printer you want to
"Open Print Queue" button. ·Step 4 Click on the "Resume
offline to online.
Step 1 Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. ·Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. ·Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online. Mac Instructions·Step 1 Open System Preferences by clicking on the icon in the Dock. ·Step 2 Go to the Print & Fax control panel under the Hardware category. ·Step 3 Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. ·Step 4 Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
perform the syeps below if you are using XP Operating SystemL
Step 1: ===== Determine if the printer is paused or offline : =============================
1.Open the printers folder, if necessary. a.Click the Start icon. b.Click Control Panel. c.Click Hardware & Sounds. NOTE: This step is not required when using Classic view in Windows Vista. d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2: ===== Check for the default printer and USe printer Online in the printers and faxes folder. =========================================================
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
hi friend this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
the message "phone off hook" is a normal message if you will used your phone, just ignore that message.
- if you cant print first thing you do is to goto start>control panel>printer and faxes then check the iocn if it is online of offline if it is offline just right click the icon and set printer online and if there is pending documents, right click again the icon and select cancel documents.
- if still the same your printing is not printing then you must uninstall and reinstall the software
