SOURCE: How to can multiple pages into one pdf file using Lexmark x4530
Open Acrobat. Under "File", click "Create PDF" then "From Multiple Files"
Remember to rate :)
SOURCE: Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
SOURCE: scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
SOURCE: HP F2280 won?t scan multiple pages into a PDF file
I fixed this by Installing the full suite of programmes on the installation CD, specifically Installing the "OCR Isis" programme (or Iris, not sure).
I had the scan-to-pdf option, but then when I reinstalled my system it was no longer available. I tried updating Adobe Acrobat reader to v9.0 and I don't think this fixed it. But at the same time I installed the "extra" programmes of the HP Installation CD, and then the scan-to-PDF feature was back.
So basically, install the COMPLETE set of programmes on the HP installation CD seemed to fix this.
I have a HP Deskjet F2180 printer, but I suspect that the HP software is generic across alot of its product range.
Cheers! - Hope this helps someone.
Darkeman
SOURCE: HP7800 scanner scans multiple pages, only saves last page to PDF
Hi
i had the same problem- I unistalled all the software and then reinstalled and load this patch PDF patch from HP solutions centre and it fixed the problemhttp://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=1151021&prodNameId=1151022&swEnvOID=181&swLang=8&mode=2&taskId=135&swItem=cs-75419-1
Regards Liz
