take the back off and get to the power supply most likely you will find some bad capacitors in it they will probaly have the tops of the caps bulgeing.
Hi. It appears that your are having a tube failure issue.
Either that, or you have a capacitor problem.
Both can act like that, but as a rule the tube acts more like that when it fails than the other parts of the tv.
The tubes are replaceable, and are available from Fry's and BestBuy.
If it winds up that it is the capacitors instead, then I would take the tv to either Fry's, BestBuy, or RadioShack. These companies have specially trained techs for just that repair, as it takes special skills to deal with the voltage and power that capacitors can hold in them.
I hope that this helps you out some, and good luck!
Off brand televisions have problems with the engineering behind their components. You will need to look for popped or buldged capacitors on the power supply mainly! Also look for any burnt resistors as these also over heat and will pop capacitors.
The power supply board is the cause.The board,where the power a/c cord plug in to it.Replaced the power supply board,will solve this problem.If its under warranty have it service.
Power LED light indication blinkings or completely dead?Yes,than the power supply board is the causes.That the board,where the power a/c cord plug in to it.Take the aparts,replaced the power supply board,will sold this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
