Where is the remote IR sensor board located in a DLP HLT5076S samsung tv as well as the ir sensor on the front of the tv
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this.
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
SOURCE: samsung 5 series 40 remote not working
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
SOURCE: SAMSUNG PN50B860 switches inputs by
I had the same issue. I ended up replacing the main board. Part number BN-94-02821B
SOURCE: IR board location
Hey Tony,
The IR board will be on the inside of either the bottom center, left, or right of the front bezel.
