Recently I changed the password on my V-safe 100 application to shorten it down but I could not get it correct. I ejected the drive after the 5th warning but when I plugged it in again and tried the password I was given the 6th and final warning. I ejected it again but now when I click on the V-safe logo it asks to set up a new V-safe folder with a new password and hint, warning me that if I continue it will be formatted and I will lose my data. Is there anyway I can get more tries for the password so I don't lose my data within the secure folder?
If you are talking about the Sim Card on a phone. Then you cannot change the password. In order to do you. You have to talk to your Phone Maker.....
If this doesnt answer your question, contact us at [email protected]
SOURCE: Error Formatting Sandisk 2GB MicroSD
Hmm.. Wired. Since you will be using it on thenPhone try formating it from the phone. any way if does not format on the phone, insert back to te computer, left click on my computer go to manage, click disk managment & see if you can see the SD there try formatting from there
SOURCE: My system restarts when I insert a pen drive. Rest
The last time I had this problem, it was a bad USB driver / chipset Driver. If you cannot find the right driver for your computer, then you will need to do a restore, so if you can give us the model number of your computer maybe we can help you find the right driver(s).
SOURCE: Please insert a disk into Drive E
Transcend provides a online recovery tool.just download that and format your pendrive with it.....that will solve your problem 100%.....
SOURCE: USB drive write protected ????
There is a small unlock tab. Please push it in right place to unlock
SOURCE: I can not access data on pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Click start click on computer to open you should your drives
C: usually your hard drive D: or E: your cd/dvd drives if you have 2 and your usb drive possibly E:or F:
Click on your usb drive right click in it select new folder option you can name it
Then put all files or data you want to password protect
Right click on the folder select properties then click sharing tab tick in make this folder private box
Another message might appear you do not have a password on this account click yes
User and password account will open for you to put in place a password
This might vary depending on your operating system in XP
Select properties then security tab at learn about access controls at the bottom of the box
Also another option to change permissions click edit
Then click deny then click apply in W7
also you might download
USB Safeguard is a portable software program to encrypt and protect data with a password on your removable pen drives using the AES 256 bits encryption.
The main purpose of using a USB pen drive is that you can bring your data with you wherever you go. But if you lose your USB pen drive your data also lose.
This is dangerous if you have confidential files stored in it. Protect the pen drive with a password. USB Safeguard offers users (novice and expert) a friendly yet extremely powerful security solution that fully protects valuable data stored on USB pen drives.
Also, the program has a useful feature that allows you to enter your email or phone if you lose the pen drive. Free version works only with USB Flash drive of size max 2 GB
hope it helps you
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS lock or NUM lock is not turned on. You should try to type your password in another application (like word or email) to ensure that it is being entered correctly. This can help you see if CAPS lock, NUM lock, or a sticky key is causing the password to actually be entered incorrectly.
Password attempts
There's a set number of attempts before U3 locks your device and you have to reformat it.
Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password you will have to reformat the drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
