Try to go to the control panel and redo your page. If not you can do a system back up to reset it into another date. If you do not know how to do this. You can get remote assistant using our website below....
Windows 7 XP Security Center
SOURCE: Reset back to factory defaults
To unlock the OSD controls when the OSD is preset to be locked, press and hold the 'MENU' button for 15 seconds to enter the 'OSD Lock' option and make
changes.
Nigel@netfishers
SOURCE: The screen says no signal but before that the
Since the hard drive was cleaned and the monitor works OK with other PC, then the question will be: Did you install the correct video card driver since the drive was cleaned? XP?
SOURCE: My monitor will not allow me to even get a menu
What is wrong with your hp w1907 lcd monitor? It won't allow you to get to the menu screen with the computer off?
The computer must control the monitor and should have a graphics card that supports the different resolutions of the monitor which will be connected to the computer via DVI or VGA.
I think your monitor is fine, unless you cannot get it to work with your computer.
Good luck on getting your monitor to work on your computer.
It's the tv, not the computer thats the problem. I can plug another tv screen and its fine. The problem is the one listed above.
Hmm, Did you try the VGA cable. If the computer is the problem, you can submit a pro request at our websitehttps://sites.google.com/site/windowssec...
Like i said not to long Ago, you can always try to reset the computer to a date it was working
I dont have any set back that far, as
I didn't know of this feature.
do you have a VGA Cable? Have you tried messing with the computer's settings having to do with the screen. Is the projector setting set correctly? To fether answer your question please submit a ticket athttps://sites.google.com/site/windowssec...
Um i think you can access at the control panel....
