Red blinking light , anti-theft system ! Your best bet is take it to the dealer (tow) . This starting system is controlled by a computer , be it a BCM - body control module or the PCM powertrain control module . Very complicated messaging between the BCM an PCM on CCD serial data bus Takes place . You need a factory scan tool to diagnose these type problems .
The engine computer has put the vehicle into "limp mode", or limp home mode. The idea of that is you can at least drive it to a repair shop, computer won't allow 3rd gear for safety or damage prevention. You will need to have the computer scanned for the trouble codes set from the blinking light. A technician or mechanic will diagnose, test, and make repairs from the information of the codes. It could be a somewhat minor electrical problem with the overdrive, but you won't know without the codes.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
Does the copier make good photo copies? Do you see any lights blinking? Is there any error messages displayed on the computer screen? What is the computer operating system?
On my two channel radio a blinking green light means that it is scanning between the two channels. I can turn off the scanning and the light stops blinking.
