I'm working on an emachines desktop that is turnkey. That is, it never prompts for username password. I want to make it prompt
SOURCE: Emachines Desktop
A simple and effective task (well most of the time) is to reseat components on the motherboard. This can include unplugging the components, including but not limited to:
Hard Drive and Optical Drive Cables
IDE/SATA Connectors
System Ram
AGP / PCI / PCI-E add in cards
Note - Never mess with the processor unless you feel qualified to do so.
If after reseating all the components, the computer still does not boot, try setting in your BIOS to start up from the CDROM and insert your recovery disc into the drive and see if the recovery detects the drive. If it does, its most likely the boot header in the file system has gone kaput. You could attempt a re-installation of Windows by choosing the repair option, however, this is a last resort thing, and if you cannot do this either, then you might be in the market for a new computer.
When a new computer is bought, you might want to buy an external USB Powered enclosure for your hard drive so you can plug it into the new tower and recover all of your documents.
I know how the failing computer feeling feels like........ So good luck!
SOURCE: im having trouble loggin in
Your account is corrupt. Either log in as an admin, recover your files and create a new account (but this way the cause of the corruption will still be there) or just do a full reinstall.
If you can't log in as admin then use a Linux Live-CD to access your files.
SOURCE: Just bought emachine bundle. Problem
many systems do not ship with Java, go to www.java.com and download and install the latest version
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop.
Click "Terminal" to open a terminal window.
Type the following command at the Linux prompt and press the "Enter" key:
sudo passwd
To change the Administrator account password, the password of "root" is changed.
The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root."
First, the user will see a Unix prompt asking for the current user's password.
Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root."
Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password.
Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset
or
Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard.
You will be presented with the boot menu.
Select "Recovery Mode" from the boot menu.
It is usually the the second boot option.
Wait for computer to boot up.
You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt."
Type "ls /home" and press "Enter." Note:
The command starts with a lower case L, not a capital i.
You will be presented with a list of usernames of accounts installed on the computer.
Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password.
Enter a new password of your choosing.
Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter."
You will be asked to retype your password.
Re-enter the same password and press "Enter."
Your password is now reset.
Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
hope this helps
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
