Hi anthony ristow, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi anthony ristow, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Ok! I fixed the issue. For those who has the same problem, I have just changed my ink cartridge.Ok! I fixed the issue. For those who has the same problem, I have just changed my ink cartridge.
Press the orange key threee times and enter 107 and then press and hold the stop key for about five seconds.
the machine then takes you into the sysytem. select sp mode on the screen. put off the machine for a minute and put on again
https://printcopy.info > brand=Ricoh > code=829
Code: 829 ; Description: Self-diagnostic Error: Optional RAM The optional RAM returned an error during the self-diagnostic test. ; Causes: · Replace the optional ...
Paper pinch roller is having some problem may be there is a paper jam or Cartridge try to remove all papers then remove the ink cartridge pull out the power wait for some time ,put back the paper without ink and paper
check if the error is changed if yes replace your ink if still there check for any paper jam clean it all properly and start again.
In most cases this error is just a scam to make you install a new carriage, that you probably don't need. Without changing anything, attempt the following procedure:
Push the maintenance key.
Once you're in the greyed out menu, type #, *, OK
This will bring you to the service menu.
Select
Select "Engine Maint."
Enter code 3009002
Select Execute, press enter.
Switch it off.
Start the printer again with the cartridge door open.
Close it upon request.
At that point a 6 minutes ink reloading procedure should start by itself (if you're using original cartridges, this will cost you an eye as half of the cartridges will be drained).
After this the printer should be good as new, if no hardware issues are present.
28113 - Ink supply timeout error (Tank 3 error)
• ink supply pump error
• air sensor error
• The tank feeler is malfunctioning.
• ink level senor error
• The ink supply pump is faulty.
• The carriage is faulty.
• The ink level sensor is faulty.
• The CTL board is faulty.
• Turn the main power switch off and then back on.
• Replace the ink supply unit.
• Replace the carriage unit.
• Replace the air purge detection switch.
• Replace the CTL board.
Hello, I have the same problem. Have you resolved this issue?
r?coh 28113 murekkep hatas?d?r. murekkeb? deg?st?r?n sorun kalmayacakt?r.
