The weedeater worked fine before but now has too loose to properly work the throttle. Hence, little power. Everything is in place and the spring looks fine. Both ends are obviously crimped so I was wondering if there was a way to adjust to tighten?
SOURCE: 325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
