GPX ML648B  MP3 Player Logo
A
Anonymous Posted on Jan 28, 2014
Fix format error
Wont work
2answers
Error 8022008B.....
If it is having trouble formatting in a PSP try taking it out and formatting it on your PC in Windows. Hope this solves your problem!
Please rate!
Cheers
System eror on mp3 can this be fixed?
You would need to format your MP3 and reinstall the firmware on it.
Be sure to get the latest firmware so your MP3 gets all the fixes possible. Format it in FAT32 using windows or if you have an application included with the factory CD-ROM, use it to format it.
Mp3 player wont play music, says file not formated
The file not formatted message is not an error that a repair will fix.
The songs that you have loaded onto the player are in a format that the player does not support. Do yourself a favor, and only download files that rae in mp3 format - they will never give you problems, error messages, require long explanations, etc.
-Tha Mp3 Doctor
2answers
Error 41
thats an internal error, firmware or formatting wont resolve.
1helpful
Error openx menu dat error
Take all the memory contents out to your computer as backup, format your memory to fat32 and put all the memory contents again to the memory from your computer. If not working try downloading the card system files from the card manufacturer site, these files are needed to run the card just like the operative system in your PC, if these files get corrupt or deleted the card wont work.
9helpful
2answers
Format Memory Card Error
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
Error code 0102
Error code 0102 is still unknown The xclamp mod is a possible fix for this error there is also a possability that the error is caused by a bad soldering join on your cpu, gpu or your ram. I would check all those parts with a magnifiying glass to make sure that there are no cracks in the solder. Another way to possibly fix this is to turn off your HD format on the AV cables this might work.
3answers
Ilo mp3 model mp-556
you must insert your mp3 into your usb port then click on My Computer icon, right click on mp3 drive and click format disk, this will resolve this problem.
Format Disc Error
Try a new preformatted disc, if this wont boot, your drive is stuffed, you may be able to format this disc in the camera but then it wont load in your computer, so its not much good, cost of repair will exceed cam value. dump it
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
