If there's film in the camera it could have reached the end of the roll and you were unaware or it didn't indicate it. Try to rewind the film and use the rewind button on the bottom of the camera. Try pushing the button in anyway and advancing the wind lever. if this isn't the problem then the internal gear is jammed or broken and the camera needs service.
SOURCE: Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
SOURCE: The film advance lever is stuck on my minolta
Here are the most likely:
A. Lever will not move on some models if the shutter is already cocked. If the shutter is cocked, and will not release with new batteries INSERTED CORRECTLY, then the most likely is this...
Two capacitors in these Minoltas die over time. If you are handy at such things, you can buy the caps, remove top and bottom covers, remove the dead caps and solder in the new ones. Don't Panic.
You can find instructions on the web for this well known issue, and you can also opt to send it to a camera repair place. Garrys camera repair in Niles, ILL does it for about $58 incl return shipping. He will also clean, lube and adjust it for ya. Something they all need eventually.
SOURCE: Film Advance levar wont work. Milnolta x-700
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
SOURCE: minolta X-9
